jrk2017
Sep 12, 2020Tutor
After update poor Backhaul
Hello, recently I've updated the firmware on my Orbi system to 3.2.16.6, but this update has caused both my orbi satellites to have poor backhaull as well as change the connection type to both 5ghz. ...
Sep 17, 2020Guru - Experienced User
Try swapping RBS around to see if one follows after the factory reset.
What kind of building materials is your home made of if you know?
When checking the RBRs web status page, make sure your waiting about 5 minutes for the system to update the status if you move the RBS around. 30 feet should be a good starting point.
