herio22
Apr 04, 2023Follower
Aggregation using iPhone as data source?
Ok, random thought - probably a no-no.. We had ISP issues this morning and it got me wondering if it’s possible to use an iPhone with an RBK853 - which has WAN aggregation - to supplement out intern...
CrimpOn
Apr 04, 2023Guru - Experienced User
WAN Aggregation on the 850 router refers to the ability to connect two Ethernet cables to a single modem to increase the data rate above 1gigabit. Before modems started coming with 2.5G, 5G, and now 10G Ethernet jacks, that was the only way to get more than 1G into the router. Modems are all abandoning that technology in favor of simply faster Ethernet ports.
That is not the same thing as supporting two different WAN sources
