folp02
Oct 18, 2020Aspirant
Airplay, Sonos and Orbi RBR750 - UPDATED
Hi there - I am having a problem with airplay - not only is it not working, but it is not even showing up as an option since getting the Orbi RBR750. I primarily use Airplay to play music over S...
- Oct 19, 2020
So the solution was quite simple - unplug all sonos devices, reboot router, bring all devices back online!
Thanks to all!
Cheers,
Mike
Oct 19, 2020Guru - Experienced User
Is the Orbi SSID name the same as what you had been using on the previous router?
If you turn OFF Sonos devices and al RBS and just connect the Airplay device to the RBR alone, does it work then?
