Ohayogozaimas
Dec 29, 2020Aspirant
Airprint not working with Netgear ORBI RBR850
Hi Guys, I am wondering if you guys could help me here. I have encounter issue with Airprint using the newly purchased Netgear ORBI RBR850 router with 2 satelites RBS850. Airprint doesn't works o...
Dec 30, 2020Guru - Experienced User
Something to contact Epson about to get there help and information regarding there printer.
- schumakuDec 30, 2020Guru - Experienced User
This isn't an Airprint issue - much more it looks like your Epson printer does fail to associate to the network, typical cause are additional bits and radio data because of the Wi-Fi 6 and/or the Mesh (802.11k/v) bits. Not the first WiFi client having compatibility issues, and not the last one. Head out to Epson...
- OhayogozaimasDec 30, 2020AspirantThanks Furry. But I did see the device under dashboard of netgear router. With IP assigned to it.
- FURRYe38Dec 30, 2020Guru - Experienced User
Probable need to run thru the setup and configuration of the printer drivers to ensure they are pointed to the right IP address. Again, check out Espons support site for information and additional help on this.
