DaveEdmonds
Jun 17, 2022Guide
All Amazon products will now not connect to Orbi RBR850
So about a week ago one of my Amazon Echo Studios reported it was not connected to the internet. This was after working fine for over two years. Attempting to reconnect to the SSID on the Orbi networ...
Jun 17, 2022Guru - Experienced User
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
DaveEdmonds
Jun 17, 2022Guide
I've done many of those steps but my point is this. It worked just fine for a very long time and then poof. I turned off RX on the 2.4ghz side and the Kindle would connect then but the Amazon Studio which is about 5 feet from one of the satellites still will not.
I appreciate the suggestions but that's a bit ridiculous for something that until last week was working then what ever may have been upgraded and changed caused it not to.
