flyerBob's avatar
flyerBob
allow specific MAC address
I am having trouble connecting an external device. Is it possible the device is being blocked? Is there a way to enable it - say by MAC address?
The Orbi Router says model RBR750
  • FURRYe38's avatar
    What device are you trying to get connected?
    • flyerBob's avatar
      flyerBob
      The model number of my Orbi seems to be RBR750.
      When I installed it, it updated the firmware to the latest version.
      the device I am rying to connect is a Phyn Plus home water monitoring system. I had it connected to a previous WiFi that I was upgrading.
      I was able to get it to connect by using 'Wireless Settings" - "Enable AX" set to enable 2.4 GHz with enable 5 GHz turned off.
      On the Phyn water monitor side, I completely reset the unit to actory settings, and then deleted the entire installation from the iPhone Phyn app; and reinstalled as if installing to a new home.
      I am not sure if I can turn the 5GHz back on. I had a problem, but there was also a power outage and reset during my attempts.
      * If I have to leave AX 5GHz turned off, will this have a negative impact on the normal function of my normal network?
      • FURRYe38's avatar
        No you can leave AX mode disaabled. You can enable AX mode on 5Ghz as well. Any 2.4Ghz only devices will not see or care what happens on 5Ghz.
