zignice
Oct 22, 2020Aspirant
Also having reboot problem with Orbi AX600
I am using the Orbi AX6000 Tri-Band Mesh WiFi System (1 RBR850 and 2 RBS850).
Since I purchased the system, it jas been rebooting itself at random intervals every couple of days or so. Sometimes a few times a day. After about two weeks, it was getting so bad that I did a complete factory reset and went through the setup process again. Everything was fine for about a month, and then it started rebooting again. Last night it rebooted, was on for about 10 minutes, and then rebooted again.
Tech support has been less than helpful and goes through the usual suggestions, firmware check, reboot. Why would I think rebooting will help when it reboots itself almost daily?
Any suggestions?
1 Reply
Please post about this over in the Orbi AX forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you.
