May 05, 2020Guru - Experienced User
Alternative to Armor and Circle on Orbi AX
Since Armor or Circle isn't fully supported on Orbi AX as of yet, user may want to review this: "To protect family/kids from malicious Internet content, DNS filtering is simplest defense and it's fr...
60sguy
May 05, 2020Aspirant
Can't you plug a Circle Home Plus into the Orbi AX6000 RBR (router) to get Circle to work? I konw it's not built in but it seems from the Circle website that Orbis are compatible?
Asking as I just ordered my Orbi AX system and was planning to do this. I really rely on Circle for my kids so if this won't work please LMK, but I'm assming it will? (I know you need to subscribe to Circle Home Plus but I'm fine with that.)
May 06, 2020Guru - Experienced User
Seems like that is a external device. Something to ask the Mfr about to see if thats possible.
60sguy wrote:Can't you plug a Circle Home Plus into the Orbi AX6000 RBR (router) to get Circle to work? I konw it's not built in but it seems from the Circle website that Orbis are compatible?
