May 05, 2020Guru - Experienced User
Alternative to Armor and Circle on Orbi AX
Since Armor or Circle isn't fully supported on Orbi AX as of yet, user may want to review this: "To protect family/kids from malicious Internet content, DNS filtering is simplest defense and it's fr...
60sguy
May 05, 2020Aspirant
Can't you plug a Circle Home Plus into the Orbi AX6000 RBR (router) to get Circle to work? I konw it's not built in but it seems from the Circle website that Orbis are compatible?
Asking as I just ordered my Orbi AX system and was planning to do this. I really rely on Circle for my kids so if this won't work please LMK, but I'm assming it will? (I know you need to subscribe to Circle Home Plus but I'm fine with that.)
tarcvf
May 20, 2020Guide
I have been using Disney Circle Home Plus with my RBK853, it works fine but you have enable Router Compatibility Mode ON
Does not work if Compatibility Mode is OFF
Also in my experience as soon as they launch Circle for Orbi RBK853, you can turn off Compatibility Mode OFF and it should work without any issue. I have been using Circle Home Plus for a while now, and it works great with kids at home.
- FURRYe38May 20, 2020Guru - Experienced User
Thank you for letting us know. Glad that solution is working until if or when NG decides to release Circle for Orbi AX.
Enjoy.
tarcvf wrote:I have been using Disney Circle Home Plus with my RBK853, it works fine but you have enable Router Compatibility Mode ON
- dtayNov 05, 2020Luminary
I've been having mixed results having Circle Plus working with Orbi AX (RBK853); like you said, it works under compatibility mode, for the most part. Every now and then I'd experience weird issues or symptoms and the fix was to disabling/re-enabling Circle, or rebooting Circle to get it working again.
Circle has updated their router compatibility with the following information. It looks like the RBK7xx (AX4200) series are compatible with Circle Plus under compatibility mode but NOT the RBK8xx (AX6000) series.
From Circle's website:
https://support.meetcircle.com/hc/en-us/articles/360022419752
✓ Orbi (Most models)⚠︎ Orbi RBR850, RBK852, and RBK853 (We are investigating issues with these routers)- FURRYe38Nov 05, 2020Guru - Experienced User
Thanks for letting us know.
