May 05, 2020Guru - Experienced User
Alternative to Armor and Circle on Orbi AX
Since Armor or Circle isn't fully supported on Orbi AX as of yet, user may want to review this: "To protect family/kids from malicious Internet content, DNS filtering is simplest defense and it's fr...
tarcvf
May 20, 2020Guide
I have been using Disney Circle Home Plus with my RBK853, it works fine but you have enable Router Compatibility Mode ON
Does not work if Compatibility Mode is OFF
Also in my experience as soon as they launch Circle for Orbi RBK853, you can turn off Compatibility Mode OFF and it should work without any issue. I have been using Circle Home Plus for a while now, and it works great with kids at home.
May 20, 2020Guru - Experienced User
Thank you for letting us know. Glad that solution is working until if or when NG decides to release Circle for Orbi AX.
Enjoy.
tarcvf wrote:I have been using Disney Circle Home Plus with my RBK853, it works fine but you have enable Router Compatibility Mode ON
