stu3886
Oct 11, 2021Apprentice
Alternatives to orbi?? (considering replacing already)
Currently have RBK853 (router and 2 satellites) failing woefully with all these horrible firmware updates and unfortunately I just don't have the time to be a member of the Netgear Beta testing t...
FiiJaS
Oct 11, 2021Guide
Hi.
Same here.
I consider to buy Orbi RBK852. I made some research and I'm not so sure anymore ...
I'm also looking for mesh system with 4 eth ports satellite.
I don't want to pay €750 and still getting some issues...
I'm afraid that there are not many other options to buy
Same here.
Wizec
Oct 12, 2021Apprentice
I’m going to try an Amplifi Alien today. Crossing fingers.
- stu3886Oct 13, 2021Apprentice
Currently reading reviews on the Linksys Velop wi-fi 6 AX5300 as a possible replacement for the Orbi
- tak1313Oct 13, 2021Luminary
Wizec wrote:
I’m going to try an Amplifi Alien today. Crossing fingers.recent review:
https://www.tweaktown.com/reviews/9905/amplifi-alien-wi-fi-6-router/index.html
edit:
Forgot to mention - it has a REALLY nice screen built in that actively shows various status information. Amplifi is a Ubiquiti brand, so it likely has great support (at least better than NG).
- WizecOct 13, 2021ApprenticeReturning the Alien today.
Range was absolutely abysmal. Also, do not buy from Amplifi direct. You have to pay for return shipping and 15% restocking fee.- tak1313Oct 13, 2021Luminary
If you like the range/coverage of the Orbi, but hate the routing, why not put the Orbi as an AP behind a better router? That's how I'm currently running with my 750s using my Asus for routing. Plus you can downgrade to whatever you want if you want to avoid the hassle of going back to .10 to do it, and just use the router to block auto upgrades.
