stu3886
Oct 11, 2021Apprentice
Alternatives to orbi?? (considering replacing already)
Currently have RBK853 (router and 2 satellites) failing woefully with all these horrible firmware updates and unfortunately I just don't have the time to be a member of the Netgear Beta testing t...
stu3886
Oct 19, 2021Apprentice
Firewall blocks definitely didnt work... orbi has forced updated to latest v4 again :(
No wonder so many people box these up and return them!
Oct 19, 2021Guru - Experienced User
You'll need to use to use the telnet method then. Seems like your ability to block using your host router isn't working.
- stu3886Oct 19, 2021Apprentice
FURRYe38 wrote:You'll need to use to use the telnet method then. Seems like your ability to block using your host router isn't working.
stu3886 wrote:Firewall blocks definitely didnt work... orbi has forced updated to latest v4 again :(
can you recommend which Firmware is the best to downgrade to so that this can be done?
- FURRYe38Oct 19, 2021Guru - Experienced User
I think I saw a post you had the 8 series, if so, "last version of FW that has Telnet on the debug page is V3.2.11.2. All versions beyond that do not have telnet on the debug UI web page,"
- stu3886Oct 20, 2021Apprentice
FURRYe38 wrote:I think I saw a post you had the 8 series, if so, "last version of FW that has Telnet on the debug page is V3.2.11.2. All versions beyond that do not have telnet on the debug UI web page,"
Downgraded to V3.2.11.2_1.2.13 and have telnet in to disable upgrade on the router. I cant work out how to do this for the satellites though? is it required?
Will the satellites still upgrade themselves automatically even if the router is saying service unreachable?
Model Name Device Name Current Firmware Version Status Router RBR850 RBR850 V3.2.11.2 Service unreachable Satellite RBS850 Orbi Satellite-1 V3.2.11.2 V4.6.3.16 Satellite RBS850 Orbi Satellite-2 V3.2.11.2 V4.6.3.16 - FURRYe38Oct 20, 2021Guru - Experienced User
Good question.
Looking at the users post regarding the telnet method, he seems to inidicate that both RBR and RBS needs that telnet config:
4. Enable Telnet option on both Router and the Satellite in their Debug.html page.
5. Telnet connect to both devices, and ran the following code to block.
Seems that the RBS need this telnet config as well. - stu3886Oct 20, 2021Apprentice
so i ran all the below on the RBR and both RBS's and it still says status V4.6.3.16 for the satellites :(
the router is all good and says service unreachable, but very worried about the satellites auto upgrading.
nvram set auto_upgrade_enable=0
nvram set ver_check_https_svr1=http.fw.updates1.aaa.com
nvram set ver_check_ftp_svr1=updates1.aaa.com
nvram set ver_check_ftp_svr2=updates1.aaa.com
nvram set ver_check_ftp_svr3=updates1.aaa.com
nvram set lang_check_ftp_svr=updates1.aaa.com
nvram set install_fw_upgrade_latest=0
nvram set ver_check_enable=0
nvram set ver_check_ftp_password=aaa@aaa
nvram set control_cloud_backend_fw_url=https://http.fw.updates1.aaa.com
nvram set promotion_server=updates1.aaa.com
nvram commit
