djlynnwood's avatar
djlynnwood
Follower
Dec 29, 2022
Amazon Fire TV 4k Max (Wifi 6)
My unit (RBRE960) with 6g network enabled, is not seen in the network menu on my brand new Amazon Fire TV 4k Max - which is advertised as a Wifi 6 device.   Netgear says the unit is compatible, Ama...
  • Mikey94025's avatar
    Dec 29, 2022
    You're confusing wi-fi 6 (which is still 5Ghz) and wi-fi 6e (which uses 6Ghz and the separate radio in your RBRE960).  The FireTV 4K Max is only wi-fi 6 and still uses 5Ghz.  From it's Amazon product page: "Supports 802.11a/b/g/n/ac/ax (Wi-Fi 6) networks."
    From https://www.tomsguide.com/face-off/wi-fi-6-vs-wi-fi-6e-whats-the-difference:
    1.  Wi-Fi 6 can send and receive data over both the 2.4- and 5-gigahertz (GHz) bands (Wi-Fi 5 is 5-GHz only) and can move even more data by running a single ultra-wide 160-megahertz (MHz) channel on its 5-GHz band.
    2. Wi-Fi 6e added more than a gigahertz of fresh electromagnetic spectrum space in the U.S., ranging from 5.925 GHz to 7.125 GHz... This additional block of spectrum, generally referred as the 6-GHz band
