DBV
May 23, 2020Apprentice
Ambient Weather WS-1001 Connection
SInce getting my AX6000, I am unable to connect my Ambient Weather WS-1001 weather console to the Orbi. I never had this issue with my previous Orbi's. Anyone else have a similar issues and if so, how did you solve it?
I did try disconnecting the satellite, but that did not work either.
Thanks for the help!
Be sure that CTS and RTS values are changed to 2347 under Advanced Tab/Advanced Settings/Wireless Settings
Try disabling AX mode on the RBR...
- DBVApprentice
FURRYe38 wrote:What Firmware version is currently loaded?
Wow - thank you so much! Disabling AX mode work! This has been driving me crazy since I purchased this router in Dec.. LOL
Will I loses any functionality by disabling AX mode?
Thanks again! :)
Yes. If you don't have any AX mode devices yet, you'll be fine. At somepoint, try enabled AX mode after you have had the WS device connected to see if it remains connected after AX mode is re-enabled.
