Chuck_M
Nov 12, 2019Mentor
Android App Unable to Connect to AX6000 intermittently
I have noticed that the Orbi App (Android) sometimes allows access/connection to my AX6000 and other times it does not and reports it "disconnected". When running the app on the WAN (not the L...
- Nov 23, 2019
Yes, I see the same issue.
Workaround is that after every time you restart the Orbi router you need to disable "Remote Management" in the app settings and enable again.
Chuck_M
Nov 14, 2019Mentor
After several factory resets of the RBS850 (with new firmware), this behavior remains and is constant. I am unable to control or monitor the AX6000 via the Orbi app when on the WAN -- accessing the system Remotely.
Once connecting wirelessly within the LAN, the app works as advertised.
Again, my setup is simple -- Cox Cable modem directly connected to Orbi. Remote access option is checked. Router has no VPNs etc.
It has previously worked -- but was intermittent often reporting "disconnected".
Now the "Disconnected" entry appears continuously.
I have deleted app, reinstalled several times (the defnition of insanity expecting a different outcome).
Since the new firmware came out, i havent been able to connect with app outside of the LAN. Is this a coincidence or a cause?
Can others please test this?
