Chuck_M
Nov 12, 2019Mentor
Android App Unable to Connect to AX6000 intermittently
I have noticed that the Orbi App (Android) sometimes allows access/connection to my AX6000 and other times it does not and reports it "disconnected". When running the app on the WAN (not the L...
- Nov 23, 2019
Yes, I see the same issue.
Workaround is that after every time you restart the Orbi router you need to disable "Remote Management" in the app settings and enable again.
Chuck_M
Nov 14, 2019Mentor
Makes me feel better that it's not "just me". +1
