Chuck_M's avatar
Chuck_M
Mentor
Nov 12, 2019
Android App Unable to Connect to AX6000 intermittently
I have noticed that the Orbi App (Android) sometimes allows access/connection to my AX6000 and other times it does not and reports it "disconnected".      When running the app on the WAN (not the L...
  • ekhalil's avatar
    ekhalil
    Nov 23, 2019
    Yes, I see the same issue.
    Workaround is that after every time you restart the Orbi router you need to disable "Remote Management" in the app settings and enable again.
