thedak's avatar
thedak
Apprentice
Jul 11, 2020
Android/iOS App won't looses connection to RBR850 (RBK853) starting with Firmware 3.2.15.25
Hi, is anyone else seeing this problem?   Starting with RBR/RBS 850 firmware upgrade to 3.2.15.25 both Android and iOS apps (adroid latest version 2.5.4.1036) loose connection to my RBR850.    After I reboot the system it will connect, but after about 6-12 hours looses its ability to connect and won't reconnect until after reboot.   Happens every time.    As a test, I loaded the previous firmware (3.2.11.2) and the problem went away.  My RBR850 is in AP mode (not router mode).  I have uninstalled and reinstalled both Android and iOS Orbi apps with same behavior.
The web gui works perfectly the entire time.  The connected devices work perfectly as well.
Any suggestions?
