MattM19179
Feb 07, 2023Tutor
Another CBR750 not working with Comcast/XF
Yo, Just came across your post.
So I'm reading through everything below, but I live in Thornton, CO and saw you're in Denver. I had Xfinity come out on 1/26/23 to do an "upgrade" to our net...
Feb 08, 2023Guru - Experienced User
Power is too high on some channels, Id ask the, to turn he power down just a bit if possible:
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
Lets give the event logs 12 hours then take another capture and post.
I see errors, criticals and warnings that the ISP will need to review and resolve if these are still seen tomorrow.
MattM19179
Feb 09, 2023Tutor
Ran the event log this AM and only had this error message hitting. Xfinity is still showing they cannot detect/send a signal to the Orbi 750.
