MattM19179
Feb 07, 2023Tutor
Another CBR750 not working with Comcast/XF
Yo, Just came across your post.
So I'm reading through everything below, but I live in Thornton, CO and saw you're in Denver. I had Xfinity come out on 1/26/23 to do an "upgrade" to our net...
Feb 12, 2023Guru - Experienced User
Your power levels on channels 23 and up and too high. I'd see if the ISP can turn this down or install a line attenuator.
Also there are some correctables there as well though not aweful.
Is wifi only going down and wired devices getting internet or is the entire wireless and wired access failing?
What channels are you using on the CBR?
Is a RBS deployed?
Not everyone is having problems with the CBR while on CC/XF ISP. Let see if we can narrow it down first.
MattM19179
Feb 13, 2023Tutor
With regards to the wifi crashing, all devices connected via wifi and the wired device I have hooked in the CBR 750 lose access until I go into the Orib app on my phone and force a reboot.
The one satellite I have is always plugged in as well in the house and that unit goes down as well.
Some of the services like my garage system, Ring system, sprinkler systems, Sonos and so forth use 2.4 GHz. Other devices like my phone/laptop are on the 5 ghz.
I will contact Xfinity about the recommendations on the power levels or the line attenuator.
