mdmahboob
Nov 05, 2021Follower
Antivirus stopped updating
Hi,
Looks like after updating firmware Antivirus stopped updating, Please find the details internet is working able to update the firmware.
Antivirus stopped udating
Model Ready NAS 424
Firmware: 6.10.5 Hostfix 1
WARNING: Your ClamAV installation is OUTDATED!
WARNING: Local version: 0.100.2 Recommended version: 0.103.4
DON'T PANIC! Read https://www.clamav.net/documents/upgrading-clamav
main.cld is up to date (version: 62, sigs: 6647427, f-level: 90, builder: sigmgr)
WARNING: getpatch: Can't download daily-26338.cdiff from db.tw.clamav.net
ERROR: getpatch: Can't download daily-26338.cdiff from db.tw.clamav.net
WARNING: Incremental update failed, trying to download daily.cvd
Trying host db.tw.clamav.net (2606:4700::6810:da54)...
nonblock_connect: connect(): fd=4 errno=101: Network is unreachable
Can't connect to port 80 of host db.tw.clamav.net (IP: 2606:4700::6810:da54)
Trying host db.tw.clamav.net (2606:4700::6810:db54)...
Can't connect to port 80 of host db.tw.clamav.net (IP: 2606:4700::6810:db54)
ERROR: Can't download daily.cvd from db.tw.clamav.net
Giving up on db.tw.clamav.net...
Update failed. Your network may be down or none of the mirrors listed in /etc/clamav/freshclam.conf is working. Check https://www.clamav.net/documents/official-mirror-faq for possible reasons.
root@TDNAS:/var/lib/clamav# clear
root@TDNAS:/var/lib/clamav# freshclam
ClamAV update process started at Fri Nov 5 16:26:03 2021
WARNING: getpatch: Can't download daily-26338.cdiff from database.clamav.net
Can't connect to port 80 of host database.clamav.net (IP: 2606:4700::6810:db54)
Trying host database.clamav.net (2606:4700::6810:da54)...
Can't connect to port 80 of host database.clamav.net (IP: 2606:4700::6810:da54)
WARNING: Can't download daily.cvd from database.clamav.net
Trying again in 5 secs...
ClamAV update process started at Fri Nov 5 16:26:09 2021
Trying host database.clamav.net (2606:4700::6810:db54)...
ClamAV update process started at Fri Nov 5 16:26:14 2021
ClamAV update process started at Fri Nov 5 16:26:19 2021
ClamAV update process started at Fri Nov 5 16:26:25 2021
ERROR: getpatch: Can't download daily-26338.cdiff from database.clamav.net
ERROR: Can't download daily.cvd from database.clamav.net
Giving up on database.clamav.net...
WARNING: getpatch: Can't download daily-26338.cdiff from db.cn.clamav.net
ERROR: getpatch: Can't download daily-26338.cdiff from db.cn.clamav.net
Trying host db.cn.clamav.net (2606:4700::6810:db54)...
Can't connect to port 80 of host db.cn.clamav.net (IP: 2606:4700::6810:db54)
Trying host db.cn.clamav.net (2606:4700::6810:da54)...
Can't connect to port 80 of host db.cn.clamav.net (IP: 2606:4700::6810:da54)
ERROR: Can't download daily.cvd from db.cn.clamav.net
Giving up on db.cn.clamav.net...
ClamAV update process started at Fri Nov 5 16:26:26 2021
Thanks
Ali
1 Reply
You might get better helpin the readynas forum and not in the AX router forum :)
New ReadyNAS Users & General Discussion - NETGEAR Communities
