jimmyngtm
Dec 23, 2021Tutor
Anyone has difficulties connecting their shelly relay to Orbi RBK852 wifi network?
I recently got my hands on Shelly 2.5 relay, and it just won't connect to my Orbi RBK852 router. Have tried disabling AX, enabling guess wifi, lowering 5ghz channel to 25%, setting static IP for the ...
Dec 27, 2021Guru - Experienced User
Did you turn OFF any RBS while working with the RBR at 25%? If you left the RBS on then there may have been chance that the phone connected still at 5Ghz.
Did you try setting up the 2.4Ghz router with same SSID name and PW long enough to get the device fully connected, then turn OFF this 2nd router? It should have auto connected to the Orbi AX signal.
Try disabling AX mode on 2.4Ghz.
Set CTS value to 2347?
