meber
Nov 14, 2023Follower
Anyone setup their separate IOT network yet?
Curious if anyone who’s updated to the latest firmware for the RBR750/850 (and others I’m sure) have setup their separate IOT network? If so, how did it go? Did you set a different password from your normal network? Also, did you have to re-setup your IOT devices to connect them to the new SSID? I wasn’t sure if the Orbi interface made it easy to move the devices over - otherwise just might be a bit of an undertaking to move all of our smart speakers, cameras, doorbells, switches, lights, etc over - if I have to reset them all.
No RepliesBe the first to reply
