AndreGr
Jan 24, 2022Aspirant
AP mode BUG: RBR750 and RBS750 do not operate properly
Hello everyone, seems I have also faced with the issue as many other already posted here on the forum: Orbi AX4200 RBK753 (RBR750) does not work properly in AP mode with its satellites (RBS750): 1...
AndreGr
Jan 25, 2022Aspirant
As per:
Its working for me with my 7 series when I tested this on v5 FW:
https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/Can-t-add-setellites-to-RBR750-in-AP-mode/m-p/2184414
FURRYe38, thank you for linking that post. I just went through it and realized that there is newer firmware version available via your link (V4.6.7.5) comparing to the firmware posted on the official website (V4.6.5.14).
Yeah, I might need to try it out as well, but gosh it will again take few hours... Bit complicated as I am helping my friend in his premises, so will need to arrange time again for new tests...
Anyway, thanks for pointing out to that post. Basically I went through the same issues as mentioned in that post...
- FURRYe38Jan 26, 2022Guru - Experienced User
Yes, give the pre-release version a try. It worked on my 7 series.
