AndreGr
Jan 24, 2022Aspirant
AP mode BUG: RBR750 and RBS750 do not operate properly
Hello everyone, seems I have also faced with the issue as many other already posted here on the forum: Orbi AX4200 RBK753 (RBR750) does not work properly in AP mode with its satellites (RBS750): 1...
SW_
Jan 26, 2022Prodigy
AndreGr wrote:Hi guys,
SW_, in case you would have time - you may try to change WIFI channel on your Router and then verify whether updated channel was applied to all Satellites as well.
Just made a change to both 2.4GHz and 5GHz channels and both changes are propagatged as expected.
SW_
Jan 26, 2022Prodigy
One thing you could try to verify if the changes are propagated correctly to all Sats is to rename the SSID to something new so that none of your WiFi clients can connect to it. WiFi clients can affect Sat's WiFi "Bands" seen via NetSpot if that client has trouble with 80MHz or 40MHz and decides to switch to 20MHz for better connection.
