doncaruana
Sep 25, 2023Aspirant
AP mode DHCP from router not displaying IP
I'm upgrading from the RBR50 (AC3000) to the RBR750 (AX4200). In both cases, I want the Orbi in AP mode and I reserve an IP address for it on the router that is serving up DHCP. On the RBR50, the LAN...
Sep 25, 2023Guru - Experienced User
Aside the WEB UI not displaying the IP address for AP mode, is the system working otherwise?
doncaruana wrote:
That's the version I'm running. Made it a point to upgrade to the latest version manually before I started doing any configuring.
doncaruana
I haven't exercised it much yet - want to make sure it's working properly before I replace my current orbi with it. It appears to be working in the limited testing I've done.
- FURRYe38Sep 25, 2023Guru - Experienced User
Seems to be a bug for sure. Mostly an inconvenience and innocuous.
I'll check my systems out as well.
I'll pass this on to NG for review.
- doncaruanaSep 25, 2023Aspirant
Thanks. I basically came to the same conclusion but wanted to make sure I wasn't simply missing something.
đ
