tserent
Apr 12, 2024Aspirant
Apple devices will not connect when switching rooms
This has been driving me crazy. When I move my phone or macs from one room to another, my devices do not have the ability to reconnect to Wi-fi. I see the network but it just spins until it says it...
- Apr 12, 2024
I would factory reset the RBS, Remove it from the RBRs web page. Then with the RBS in same room as RBR, get it resynced wirelessly. After is all back up and running, place back in same location and test. I might turn OFF the other RBS to help check this as well.
tserent
If it follows the satellite, then what should I do?
Apr 12, 2024Guru - Experienced User
