brandobot
Jul 02, 2023Guide
Apple iPhone/iPad Connection constantly drops
I have the same exact issue on my iPhone 14 Pro. Other devices remain connected, but wifi drops and I get a self assigned IP. The device ends up reconnecting after 1-2 minutes.
brandobot
Jul 02, 2023Guide
Rkbe963 (router and 2 satellites)
Only customizations I did was setup wireless, disable UPNP, disabled 20/40hz coexistance.
I have randomized MAC disabled on my iPhone. Other devices on my network ( macOS, Windows pc, Google Home cameras/devices, TVs all work fine)
Jul 02, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰️
Does this happen with the RBS turned OFF?
What channel configurations are currently set on the router?
Are the separate 6Ghz and IoT networks enabled on the RBR?
Is Armor or SPC enabled on the RBR?
