solosys
Aug 12, 2022Aspirant
Apple TV 3rd Generation with Netgear Orbi RBRE960 AXE11000
This past week I experimented with the AX4200, AX6000, and now I have the AXE11000 system. All of our Apple TV 3rd generation devices can no longer connect to the Orbi network. However, it does conne...
Aug 12, 2022Guru - Experienced User
Try forgetting the wifi profile on the ATVs and then attempt to reconnect?
Do you have the separate 6Ghz SSID broadcast enabled or no?
How do you have the wifi and security settings set up for on the RBR?
Is WPA3 mode only set or Mixed WPA2 and WPA3 set?
- solosysAug 12, 2022Aspirant
I've reset the Apple TV to factory defaults and they are updated to the latest software. I tried with both the IOT and 6GHz networks enabled and disabled. With security, I have both WPA2 and WPA3 enabled on the 2.4GHz and 5GHz.
- FURRYe38Aug 13, 2022Guru - Experienced User
Just as a quick test, what happens if you disable WPA on the RBR temporarily. Does the ATV connect here? Re-enable WPA after trying this.
Might connect the ATV via Ethernet as well...
