astonerii
Sep 21, 2020Star
Are all RBR750s defective?
Apparently first post was to wrong forum. Are ALL RBR750s defective? RBR750 ORBI RBR750 V3.2.16.6_1.4.4 The symptoms of the defective units in my case are. My phone will show it t...
larryindublin
Sep 21, 2020Luminary
I upgraded from an RBK53 set to the RBK753. Kept same SSID and all default settings (except added smtp for log emails). Everything reconnected, connection quality is as good if not a little better (My Note 20 Ultra is only device that supports Wifi 6). One Satellite is in the basement, 1 is on the first floor and the router is with the ISP cable modem (Aris 6183, modem only) up on the 2nd floor.
Only problem I've seen so far seems to be a pretty well documented but not fixed yet issue with DNS occastionally.
Have been on several multi hour video calls with no issues while others are streaming netflix.
Not sure why some people have issues while others see Orbi as rock solid.
