MooseBoys
Oct 28, 2022Follower
Are all the Orbi 6E units interchangeable?
The Orbi 6E system seems to only be sold in 3-packs (RBKE963), 4-packs (RBKE964) and as an "Add-on Satellite" (RBSE960). I have a lot of questions: Are these, in reality, the same single hardwa...
Oct 28, 2022Guru - Experienced User
Yes.
NG recently has come out with the RBR single unit. So you could start off with that first and then you can add on a RBS, one or more at a later date:
You can use un-used RBS with another RBR 9 series at a different location.
