steinOA
Nov 21, 2022Follower
Are ORBI RBK352 AX1800 compatible with RBR20
Have a Orbi RBR20 with two sattelites and want to extend with an extra satellite. Didi find an BlackWeek offer on RBK352 router and satellite. Will these be compatible?
- Nov 21, 2022
No. They won't be.
For the RBR20 system you'd need either:
RBS20, RBW30, RBS40, RBS40V, RBS50, RBS50Y
You can also use the rbs10 but its a dual band and not triband
Nov 21, 2022Guru - Experienced User
No. They won't be.
- plemansNov 21, 2022Guru - Experienced User
There's another chart to if you plan on upgrading at some point.
https://kb.netgear.com/000065169/Which-Orbi-routers-and-satellites-are-compatible
