guptaus
Sep 03, 2022Follower
AT&T Fiber and Orbi RKB753
Hi All,
I upgraded to AT&T Fiber Optics about a year back. I was using Google mesh router Gen 2. After struggling for a few months, I upgraded to from 600mbps to 1 GB. Not great so, upgraded to Orbi RKB753S with two satellites in December, 2021. It worked fine for a while, and then the past few months, the WiFi has been disconnecting randomly and re-starting after a minute or so.
Had the AT&T tech come out. She said that the Orbi router was too close to the AT&T modem. So, I moved the router downstairs, hardwired. It still disconnected last evening. Called AT&T and they said that no dropouts on their end. They think it is a compatibility issue and recommended replacing the Orbi router with AT&T wireless extenders. Reading the reviews of AT&T wireless extenders, this sounds stupid. I am at my wits end and could use some advice.
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopTry option #2...
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
