donawalt
Feb 06, 2024Hero - Experienced User
ATTN RBR960 Orbi network users! Need a piece of info from you
HI all, we are trying to hunt down an anomaly that may be an issue and may not be - namely, that the 960 series of Orbi routers seems to regularly use more memory out of its 818MB than older Orbi sys...
Feb 13, 2024Guru - Experienced User
Can you post the system uptime see on the debug web page as well please.
spewak
Feb 14, 2024Luminary
Keep in mind, I reboot my unit at least once a week.
- donawaltFeb 14, 2024Hero - Experienced User
Thank you for all your replies! As we research this further, I am going to make an educated guess on whether or not you have IPv6 enabled (or have the service from your ISP. Can you confirm whether or not you have IPv6?
Has IPv6 enabled:
Does not have IPv6 enabled/operational:
Thanks for your assistance!
- knightz01Feb 14, 2024Apprentice
Enabled but not provided.
- TC_in_MontanaFeb 14, 2024Virtuoso
I think it may be more than just IPv6 or not. I think it may be a combination of BootLoader and IPv6 enablement.
I do have IPv6 enabled (6to4) although not sure it is actually functional as I am double-natting the 960 right now.
But I also have BootLoad V5 instead of 6.
I'm sure we will find the combination at some point in time!
Good point TC, I bet you are right - IPv6 plus new ver 6 boot loader. I ran IPv6 for a long time on my 3 or 4 year old 850 series Orbi, and did not see this memory difference on the router.
- owlynFeb 14, 2024LuminaryYes, I have IPv6 enabled.
Note: If you have the router set to Auto, it may not configure IPv6 properly or at all. Try DHCP first.
