maccabout2's avatar
Dec 31, 2021
AX 4200 best Installation in 4 level home
Just bought the AX4200 wifi 6 system with 2 satelites for improved wifi quality in my 4 level home (including concrete basement). Internet router is currently in the basement, next to the internet box from the service provider.
Where should I move the internet and Orbi router to for best performance?
Where should I install each satelite for best coverage given there is wifi activity on all floors?
  • plemans's avatar
    Jan 02, 2022
    That generation of homes tends to be a bit challenging as a lot of them were built with plaster lathe on the interior walls. Tended to have metal in the plaster and do an excellent job of blocking wifi. Not sure about your place or if it was remodeled at all.
    But I'd try several positions to see what works best.
  • plemans's avatar
    there's not a simple answer for you.
    In terms of the router, the best location is centrally located. Its not always the case since you have 2x satellites.
    In terms of the satellites. Sometimes you have to play around with them as objects in the walls/ceilings can block signal.
    When I first started using mesh, I would setup the system and leave it for about a week and then move the satellites around. Each time I would test each location to see which was th best. The good thing is you only have 2 satellites to move around and test. I tested from 1 to 4 satellites and did a lot of moving around. It took a while.
    So there isn't a simple answer other than to try different locations to see what works best.
    • maccabout2's avatar
      maccabout2
      Guide
      My home is 4,000 sq ft over 4 levels (including basement). Built in 1920.
      There will be at least 30 feet between the router and the various satelites, each satelite on a different floor (1st and basement). The satelites will each be at opposite ends of the house on different floors.
      2nd, 1st and basement will be diagonally opposite from each other in each case. No plans of having any satelites on the 3rd floor.
      • plemans's avatar
  • FURRYe38's avatar
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
    https://kb.netgear.com/000061709/Where-should-I-place-the-Mesh-WiFi-satellite-of-my-Nighthawk-Mesh-WiFi-6-and-Tri-band-Mesh-WiFi-6-products 📡
