JSFJSF
Jun 08, 2021Aspirant
AX 4200 RBS750 - Additional satellite to connect wirelessly to another satellite?
I have just installed a router + 2 satelittes and this is not enought to cover my entire house. I would lke to know if I can just add another satellite but WITHOUT wiring it, i.e. if it can jus...
- Jun 08, 2021
Brick and concrete will be problematic for any wifi system. Hopefully it will work ok for you. You can ethernet connect the RBS as well:
JSFJSF
thank you.
House is about 5000sqf and building material brick, concrete
Sounds like adding a satellite through a daisy chain should do the trick. I've ust ordered another satellite. Thanks for the tip (i just learned what a daisy chain is...) and I'll report the result here for
Cheers, JSF
Jun 08, 2021Guru - Experienced User
