Hari_kb
May 20, 2021Aspirant
AX 4200 satellite poor wifi
I set up Orbi router plus 2 satellite AX4200 system in my home 3000 sq ft, 2 story. the satellites are placed in different rooms but about 20 linear feet away. I have a gig fiberoptic zipfly co...
May 25, 2021Guru - Experienced User
What devices are you using to speed test with?
30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Wifi speeds depend on connection rate, MIMO antenna support and OFDMA which Orbi AX doesn't support from what I was told.
Most phones and pads are 2x2 MIMO antenna design and max out at anywhere from 300-500Mpbs on wifi.
Connection rate depends on the connection support by the device and the host wifi router. AC rates max out at 1733Mpbs and AX is 2400Mbps on 5Ghz, Depending on support and design of the host router. https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
I've seen my iphone 12 max get around 500-700mpbs. My Mac Book pro 2018 has seen 700Mpbs with Orbi AX. Using a non NG orbi mesh system, I've seen my iphone get around 900Mpbs however that system supports OFDMA.
Hari_kb
May 28, 2021Aspirant
thanks for your response. I use my samsung laptop and my iphone max to check. On both, I got around 500 mb while I am next to the router. but about 300 when I am next to the satellites. I just upgraded my service to zipfly gig. their model is integrated inthe setup in my garage. I will check it and also will re-position my router based on the recommendation from your link.
The speed once stabililzed has improved form 150 to 300 already. I am happy with these numbers for my need, once I do minor tweaks, I think I should bump it up. Will play around this weekend and will update.
thanks again for your response.
- FURRYe38May 28, 2021Guru - Experienced User
:smileywink:
