Hari_kb
May 20, 2021Aspirant
AX 4200 satellite poor wifi
I set up Orbi router plus 2 satellite AX4200 system in my home 3000 sq ft, 2 story. the satellites are placed in different rooms but about 20 linear feet away. I have a gig fiberoptic zipfly co...
Hari_kb
May 28, 2021Aspirant
thanks for your response. I use my samsung laptop and my iphone max to check. On both, I got around 500 mb while I am next to the router. but about 300 when I am next to the satellites. I just upgraded my service to zipfly gig. their model is integrated inthe setup in my garage. I will check it and also will re-position my router based on the recommendation from your link.
The speed once stabililzed has improved form 150 to 300 already. I am happy with these numbers for my need, once I do minor tweaks, I think I should bump it up. Will play around this weekend and will update.
thanks again for your response.
May 28, 2021Guru - Experienced User
:smileywink:
