GreggCFO
May 05, 2020Aspirant
AX 6000
I have an Orbi RBR750 router with two satellites an RBS750 and 850. I would think that with Mesh i would walk around my house and the phone or laptop would switch automatically to the strongest point...
May 05, 2020Guru - Experienced User
Be aware its up to the connecting devices to pick and choose where they connect to, based on signal, noise and envrionment and there design. They may not disconnect from a low signal source until it's fully out of range or like you did, turn off the wifi radio on the decice then back on, then the device connects to the more stronger signal.
