Denveronly
Nov 10, 2020Aspirant
AX is not turning on on Orbi router
hi there, i turn it on in the router webmenu, the router reboots, but no changes. It is still off
Denveronly
- FURRYe38Nov 16, 2020Guru - Experienced User
What broswer are you using?
Try IE11, Edge or FireFox or Opera to see if same thing happens.
