Wisconsinguy
May 02, 2020Follower
AX series Wifi 6 Router does not send data to wired printer
Hello Set up: Working all wifi and ethrnet through Orbi router on passthrough from my ATT wb210 router. I turned off teh wifi on the att and am running teh modem passthrough to my new netgear r...
May 02, 2020Guru - Experienced User
Turning off the wifi on the att device doesn't put it in passthrough mode. And att's passthrough mode is sketchy at best.
https://www.reddit.com/r/Ubiquiti/comments/b1x5l6/how_to_properly_configure_the_arris_bgw210_for/
If its not running properly, setup properly, you'd be in a double nat which could cause your issues.
https://kb.netgear.com/30186/What-is-Double-NAT
