MK2022
Mar 10, 2022Aspirant
AX WIFI on ORBI RBK 752 - 2 pack mesh
In order to enable AX WIFI connection on the ORBI RBK 752, do I need to set up my WIFI network using WPA3? In such case, are older devices capable of connecting to this network on AC or 2.4 GHz frequ...
Mar 10, 2022Guru - Experienced User
No.
You can use wpa2. Some older devices don't function/struggle with wpa3.
AX will still work fine.
