DougPueblo
Sep 02, 2022Follower
AX11000 Quad-Band Orbi WiFi 6E Router - Black Edition (RBRE960B) won't connect to starlink
I tried for a couple of hours to connect these two and then did some digging only to find out there is a whole bunch of us with the same problem. I read when another customer used a Netgear S350 Seri...
- Sep 02, 2022
Yes thanks for letting us know. Others found as well that using a non managed LAN switch makes it work.
Enjoy. 📡
Sep 02, 2022Guru - Experienced User
Enjoy. 📡
