td318
Apr 19, 2025Follower
AX3000 Mesh WiFi 6
192.168.1.1 will not connect from a laptop. Turned off VPN Turned off Firewall Turned off Anti-Virus still won't connect tried different Browsers Still nothing. Hmmm… can't reach this page 192.16...
Apr 19, 2025Guru - Experienced User
What browser are you using? Be sure to clear out all browser caches.
Try a different browser.
Has a power off for 1 minute then back ON with the ISP modem and router and satellite(s) been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed?
Which Orbi model do you have? 350, 750 series?
