ejvalle58
Apr 29, 2020Aspirant
AX4200 - 2 pack (RBK752) Lignts On Front
Are blue lights on the front of the router and sattelite supposed to be on?
Bandito
Apr 29, 2020Luminary
Once everything is established and up and running properly the LED should turn blue for about 2 minutes. It should then turn off.
ejvalle58
Ok so if the light turns off the system is working as intended?
- FURRYe38Apr 30, 2020Guru - Experienced User
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
