syphon
Dec 09, 2020Aspirant
AX4200 - rbr750 and two rbs750 - throughput concerns.
What are people getting interms of throughput on their orbi systems? What I'm using Test setup For conversion, https://www.gbmb.org/gbps-to-mbs 4.2GBPS = 525MB/s (theoretically) Internet ...
syphon
Dec 10, 2020Aspirant
Anyone have any real world speed test internet or peer to peer?
thanks.
- FURRYe38Dec 11, 2020Guru - Experienced User
These are wireless speed tests results with a Mac Book Pro 2018 5Ghz AC mode:
This is with a 8 series Orbi.
Wired speeds are usualy around 900Mpbs or just over on my ISP 1Gb/50Mbps Plan.
- syphonDec 11, 2020Aspirant
Thanks for the response. What is percentage of the total speed are you reaching through wireless? Also, is the bandwidth instant on to that or starts at 20 or 30 % capacity then hits the indicated number?
thanks.
