syphon
Dec 09, 2020Aspirant
AX4200 - rbr750 and two rbs750 - throughput concerns.
What are people getting interms of throughput on their orbi systems? What I'm using Test setup For conversion, https://www.gbmb.org/gbps-to-mbs 4.2GBPS = 525MB/s (theoretically) Internet ...
Dec 11, 2020Guru - Experienced User
These are wireless speed tests results with a Mac Book Pro 2018 5Ghz AC mode:
This is with a 8 series Orbi.
Wired speeds are usualy around 900Mpbs or just over on my ISP 1Gb/50Mbps Plan.
- syphonDec 11, 2020Aspirant
Thanks for the response. What is percentage of the total speed are you reaching through wireless? Also, is the bandwidth instant on to that or starts at 20 or 30 % capacity then hits the indicated number?
thanks.
- MstrbigDec 11, 2020Master
syphon wrote:Thanks for the response. What is percentage of the total speed are you reaching through wireless? Also, is the bandwidth instant on to that or starts at 20 or 30 % capacity then hits the indicated number?
thanks.
This is my constant wireless speed using RBK753 system with IPv6 active. This was on my Win 10 laptop through one of my satellites.
I was getting below 500 down before activating IPv6. The second test is my Cellphone. It is actually has a network connection speed of 910Mbps because of AX mode support. So it makes some difference.
For some reason it takes a bit for my pics to upload to the forum's sever.
- FURRYe38Dec 11, 2020Guru - Experienced User
Well for the mac book pro wireless which only supports 5Ghz AC mode, the speeds I'm seeing is pretty good when connected at 1100-1300Mpbs connection rates.
If you look at the two lines in the results window, you see how the tracking of the speed happens. Always seems to start low then it climbs up to higher speeds.
I'd really be curious to know what speed you're getting from peer-to-peer transfer on wireless. If you have the time if you could use that tool above that might help me undersand if there is something not being done on my part and i can reach out to netgear support.
