syphon
Dec 09, 2020Aspirant
AX4200 - rbr750 and two rbs750 - throughput concerns.
What are people getting interms of throughput on their orbi systems? What I'm using Test setup For conversion, https://www.gbmb.org/gbps-to-mbs 4.2GBPS = 525MB/s (theoretically) Internet ...
Dec 11, 2020Guru - Experienced User
Well for the mac book pro wireless which only supports 5Ghz AC mode, the speeds I'm seeing is pretty good when connected at 1100-1300Mpbs connection rates.
If you look at the two lines in the results window, you see how the tracking of the speed happens. Always seems to start low then it climbs up to higher speeds.
syphon
Dec 11, 2020Aspirant
I'd really be curious to know what speed you're getting from peer-to-peer transfer on wireless. If you have the time if you could use that tool above that might help me undersand if there is something not being done on my part and i can reach out to netgear support.
- syphonDec 11, 2020Aspirant
definitely thanks forr taking the time to response and provide your screenshots.
- MstrbigDec 11, 2020Master
syphon wrote:I'd really be curious to know what speed you're getting from peer-to-peer transfer on wireless. If you have the time if you could use that tool above that might help me undersand if there is something not being done on my part and i can reach out to netgear support.
https://www.aja.com/products/aja-system-test
This llink you have here is for hard drive read write speed, not any type of network speed test. Since my speedtest images did not populate, my speedtest was over 550Mbps download and 59Mbps upload speed on an ISP plan for 500dn/50up
- syphonDec 13, 2020Aspirant
If you actually download it you will see you can specify the destination as the network share volume/folder. It can proivde you a data transfer speed test peer-to-peer through orbi between the 2 SSD devices. Network speed test can be ISP or peer-to-peer on the LAN. I have ISP numbers and thanks for sharing them in the thread. But I was also looking for file transfer speeds. To see just how fast LAN transfer rates are.. I was getting 23 megabytes with less than 15 feet from AP and satellite. Wondering what people are getting. By using the tool i found. Unless anyone knows a better tool I'm all for standardiziing test bench tools.
- MstrbigDec 14, 2020Master
syphon wrote:If you actually download it you will see you can specify the destination as the network share volume/folder. It can proivde you a data transfer speed test peer-to-peer through orbi between the 2 SSD devices. Network speed test can be ISP or peer-to-peer on the LAN. I have ISP numbers and thanks for sharing them in the thread. But I was also looking for file transfer speeds. To see just how fast LAN transfer rates are.. I was getting 23 megabytes with less than 15 feet from AP and satellite. Wondering what people are getting. By using the tool i found. Unless anyone knows a better tool I'm all for standardiziing test bench tools.
I'm very familiar with the program. However your test results would still not be accurate, as you are also rating the data transfer rate of the hard drive plus network. If you do a search for internal network speed, you will find programs that will give you that info.
