DJ1964
Apr 16, 2020Guide
AX4200; can I connect my current Dlink router
Hi - i have comcast cable internet and currently a dlink wifi router. can i connect the cable modem to the orbi ax4200 router, and then connect the dlink router to either the orbi router or its sate...
- Apr 17, 2020
Glad that worked for and your getting great speeds. Sounds like time to enjoy now. :smileywink:
DJ1964
Apr 17, 2020Guide
well, that was easy. I see what you mean about just calling it by the old network's name and password. Given it was specified on a tag on the router, I thought it would be more difficult to change, but it was simple. I'm pulling down 400mbps on the other side of the house where I've never got over 50mbps at 2.4ghz and over 100mbps at 5ghz.
I'm happy...hope it is rock solid.
