defiler2k
Nov 28, 2021Aspirant
AX4200 Magenta light and Internet drop daily
I have been facing the issue that my router drops connection to the internet daily. The router goes to the solid magenta light, none of the wired devices can even communicate with it and I can only c...
Nov 28, 2021Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
defiler2k
The cablemodem is an Arris Surfboard 8200, has been working just fine until Friday. Yes both devices have been power cycled (full disconnect for over a minute) and the router has been factory reset.
From the article, there is no description for what solid magenta represents.
- FURRYe38Nov 28, 2021Guru - Experienced User
Ya, that KB article needs to be updated.
Theres BLUE when the RBR connects then turns OFF or ON with Magenta solid if the RBR looses the connection to the modem or the modem fails to give an IP address to the RBR. I'll have NG review this article and get it updated.What is the CAT# of the cable in between the modem and RBR?
Try a different cable to check this.
- defiler2kNov 28, 2021Aspirant
I have tried multiple cat 5e cables, I even bought a new one just in case, same issue.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
